I've came up with a solution for the casting flaw
I'm jealous.
The right port anchor studs are close enough.
Yes I have and there far better pros to using JB Weld, much more forgiven in reshaping especially when working the short turn, provides an insulatedJack, have you ever considered using D shaped aluminum tubing to make your ports?
Thanks for the kind words but this type of anchorage is common practice and for the XS I think this is the best approach addressing vibration frequencies.Simply brilliant Jack!!!
No I'm not, it's a real PITA trying to weld up the E/P ,most always the end result is burning through the short turn. Once the ports are cleaned up ,they flowJack, are you considering D shaped exhaust ports as well? I've read that Chevrolet is using D exhaust ports on Corvette engines now.
