jurgenkoppen
Backwoodsfreak
So my 79 650 which ran great for years since I installed the solid state regulator and the Pamco ignition and coils is now giving me charging mysteries.
Going with your most excellent testing procedure, I determined that my rotor had packed it in, I did not get my 5 ohms nor did it slap the case. So I had another rotor at hand, a rebuilt unit from a rebuilt-guy I vaguely remember under the handle Tim and a memory of him not communicating, which I had purchase a few years back. Stuck it in, and yay, it worked .....albeit only for about 3 miles. Then it charged intermittently, on for a few miles, then off again, according to my red charge indicator light. So I had to go back at it again, checking all connections, since it appeared to be a loose connector judging from the intermittent-ness. However, no luck there, all connections were OK. So I did the ohm test and , the "new" rotor shows no connectivity at all. So, did I just received a test in patience, or am I somehow inadvertently frying my rotor(s)??? I had a 10 amp fuse between my GM regulator and the brush, instead of a 7.5 amp, and at one point it blew. Anybody out there to enlighten me. I seems to be a bit dense right now...
