Chopper wireing diagram
Cafe Murdock
Murdock
Rio grande ohio
I've got a stock 79 650 special I'm n need of a diagram to wire my bike like a chopper or bobber with only tail/brake light head light and power for my coils and point I'm following the genies of the great Bryan Durk out of Minnesota by doing away with my mechanical reg/rec and going to a later modle combo unit set up I have a basic working knolage of wireing I work n a garage and fab fab n no alot about machineing n fab and engine work but wireing takes me a minute sumtimes ne help would b great thanks guys
Diagrams are in the Tech section.
I'm wanting to switch from a stock 79 650 special harness to a bare bones style one kick only that uses a combo reg/rec unit there's a guy names Brian durk that has a vedio on utube that is usein this set up
I looked at them n they didn't make alot of sence I'm not to great with wirein
Well... there are some chopper diagrams in there that are as easy as they get. Good luck.
Wiring in an A type, (points Model), SS Reg/Rect
http://www.xs650.com/threads/wiring-in-a-70-79-combined-reg-rect-to-a-points-model-xs650.52339/
Some of the cheap Aftermarket SS Reg/Rectifiers are just that.....Cheap......they have been known to have problems so most guys on here change to Automotive regulators and a single 3 phase Bridge rectifier, or 2 single phase bridge rectifiers as per RG's, (Retiredgentleman), posts in the links below.
As an Alternative to a SS combined Reg/Rect .............Read Retiredgentlemans posts from Post #3
http://www.xs650.com/threads/regulator-rectifier.21485/
Post #2 some more Automotive Regulators that can be used for Points model bikes.
http://www.xs650.com/threads/pre-1980-regulator-non-nylon-screw-version.10699/#post-109435
3 Phase Bridge Rectifiers, some come with a heat sink.......35amp is all that's needed. The heat sink one is 50amp, it would work but there may be some 35's as well.....cheaper
https://www.ebay.com.au/itm/2pcs-Br...m2ce6c3c3d9:g:RnAAAOSwCnpcgduj&frcectupt=true
Would need to make your own heat sink .........35amp
https://www.ebay.com.au/itm/3-Phase-Diode-Bridge-Rectifier-35A-1000V-SQL35-CH/133020533078?hash=item1ef8a44156&_trkparms=ispr=1&enc=AQADAAAC8FjVrDbVsZ8oH/8PNHtt9VX4/w7FZcmMuqsX8uaFEduVD+iqYQEH20MrIXSdJIXylhFPUnfirm4LEHaU3tZ+RHHLXx7vV6uwwCU10RsuEO50sG6N4+v+PsvJlhvvZMg0JWSYKzx8gaIv0TezsN693cxHXz4LHTxPLzqckIJsYZJlhQToLCYnUA95CpqbcZRWzZwfsKfTQLr+FXWqcnSmqBP2Kiz8tYdGZoIgVZ0zMFwRgnm/721pGz342Nxf1kEICkgz1OVVF5bdQ/7NIGeLUOn0AgWcM0F+rFDhsNAFPKaB8pisms1h/xSy8NWFO20WITsBCE4zAFfHlRU5+5tAoAauHytJncXcthNJ0jS6d88b9uLbE6l2BV101yrEtSbFe7p+g0k60SNlYCkeW93aM+uSqdd8AyRngoNCgbMk6i8pi47Et3xjtDNBAvOuV4XcZpIaigZtJhyQNfFrd6IEMtwh59rZVDw182WwAWHbQ1FEd7T45RhEOXaf1mVlPaLODPyzfy/QOn7DXeuf3LuvqCvMoZw4SJ5mWxC/5A3//ErqmL8GCsevkoimJa2eqTirR7VudzoQCqWZ9Qcsw3BpQ94mDc6hz4g4hGcO9626h0flTihJIuaQbCUjK6NnNCYjzcBlA2443Y5fLaAEJXNXhXN9e4S7SKV5PIYiR91NEebSmWVcYYs9LV3zhE6VejBGmYA84xgOBNTFGPAY2mdpMTo44aAEn/Kew7wVTtv6nAPzCfFvTsqSQjtpmPE23nEeqmG0X9omiYTJFIG0rsMXKtyeCJw+6iGuzHFQTF6dKFTgCfScQDsbsEF6cn8ya4UQqIYKHXE44oytOI8OQmosA0q3GNkIJ1AaMV/4wPmlf5toXCovNkpyKjfc3CrjMkkmk3zpTrwl1IzFOK71TCnKDjE9mfZr9CEksWb7b1n10knCxgEL7jCMw6UNGxZtaPe4i+Im2rdLKQOVQE+WnV4hUwSVloP5aPPFl3uw1a+jxoHN&checksum=1330205330784c205187c49946b9b61a5c95ab00a9e0
Another option would be to hit up Rich aka "DaddyGcycles" in the swap forum. He builds nice harnesses for reasonable price.
