1. Dismiss Notice
    Dismiss Notice
Cleaning Carbs
Discussion in 'The Garage' started by Benjamin, Aug 31, 2009.
Tags:
  1. Terry Bishop
    Terry Bishop XS650 New Member
    2
    0
    1
    Like the the info here alot. I am new at working on bikes. My 650 sat for a year and now has no mid or high range speed. Crack the throttle and it just stalls. I think this carb info is going to help alot.
  2. Buccaneer
    Buccaneer XS650 Member
    Hi all,
    Does anyone in UK / EU know where to get Sea Foam or is there an equivalent over here?
    Cheers in anticipation!
  3. gentlemanjim
    gentlemanjim More Wrenchin than Ridin
    Chevron Techron the best product in the business
  4. njrmahoney
    njrmahoney XS650 Enthusiast
    I came across this video, for me it was very helpful.
  5. gentlemanjim
    Informative, but leaves a lot out of a full rebuild.
  6. mkesbest
    mkesbest XS650 Addict
    random ? but do all carbs have a bracket holding them together? I have a 76xs and they were separate...2 minuki bs 38s. Do I need a bracket? and if so where could I find one?
  7. gentlemanjim
    On your bike you do not need nor was a bracket installed from the factory
  8. mkesbest
    thanks...was worried about that...im sure im missing pieces since its sat for ever...glad that's not one of them!
  9. TheRunaway
    TheRunaway XS650 Enthusiast
    Great info on carb cleaning thanks Travis!
  10. davebraun444
    davebraun444 XS650 New Member
    As with everything else on the left coast, Seafoam has been known to cause cancer in the state of California. You just need to cross a state line where you can bathe in the stuff without a problem.
  11. XSLeo
    mkesbest, on carbs they used two separate carbs, two throttle cables. up to 75. In 76 they started using the linked carbs. They use one throttle cable.
    Your 76 should have come from the factory with Linked carbs.
    If you have the two separate carbs, a PO must have swapped then out. This is not a problem. They will take just a bit more maintenance to keep running at their best.
    You need to determine just which carb set you have. Yamaha changed carbs every two years. As in 70-71 was a set, 72-73, 74-75, 76-77, you get the idea.
    www.xs650.fi/pohja_files/fi/XS650carbs.htm is a ID guide for the BS38's It was translated through a couple languages so some of the wording is hard to understand but the pics help a lot.
  12. I have been using this fuel treatment for several years in all my bikes, antique tractors and generator...Never any issues with dirty carbs... Not snake oil, or a mechanic in a bottle, Just chemistry at work..
  13. I have a problem with my carbs
    I took them off to clean them and one of the pilot jets was stripped and I can't get it out to clean it properly
    So I just cleaned everything else and when I start the bike and let her run I get a popping sound from the exhaust
    I dropped my carbs in a solventvtank tank for a few days hoping to clean them out
    Is there any way to get the pilot jetvout or could the popping be something else
  14. TwoManyXS1Bs
  15. Thanks TwoMany
    Gonna do my research so my new bitch can run properly
  16. YamadudeXS650C
    YamadudeXS650C Central New York XS650 XS650.com Supporter Top Contributor
    If you are unable to get the jet out, perhaps you could clean it in place by carefully using the proper sized orifice tool. They are inexpensive.
    Yes, the popping could be something else, as well.
    It typically is due to a lean mixture, such as leaking at the exhaust manifold gasket at the head (popping upon decel).
    If you search for "popping" in Garage you will get lots of threads to study.
    Good luck with the carb.
  17. Dave79sx650
    Dave79sx650 XS650 Member
    Best place to buy carb rebuild kits
  18. grizld1
    grizld1 Grumpy old man Top Contributor
    Simple answer, given many times: Don't! Rebuild kits typically contain generic items that won't work, stuff that you don't need, and all too often substandard repop brass. It's best to decide what you need and order genuine Mikuni parts individually.
  19. Dave79sx650
    Thanks you
Share This Page
