If your clutch is working ok now, I might try it as is. If in doubt, then upgrading the springs is a good first step.
I had trouble with slipping when I added the 750 kit to my 75. It acted about the same with the 75 7 plate clutch as it did with the 82 6 plate clutch. I started by cleaning the steel plates with 120 grit sandpaper, to clean off any discoloration as well as remove any burrs and rough edges. The steel plates are punched out. This leaves a slightly rounded edge on one side and a sharp edge on the other. By removing and slightly rounding this sharp edge the plates slide in the basket with out binding.
This coarse sanding left the surface of the plates slightly rougher, improves the grip on the fiber plates.
I also roughed up the fiber plates a bit. This helped, but it still slipped a bit and got worse after a bit of running.
I found a set of NOS Kibble White 70 lb springs on Ebay and got a set of Forodo plates.
With the new plates and springs, a new worm, mine was cracked, well lubed worm and cable and my clutch works great. The new worm I got from Mike's has a lomg arm with two holes to attach the cable. Use the hole closest to the worm. This position opens the clutch a bit farther, minimizing clutch drag. This makes finding neutral easier.
You can try the hole farther away from the worm, it doesmake the lever pull slightly less, but it doesn't open the clutch as far. This increases clutch drag, making neutral harder to find.
With the worm set this way, well lubed with a well lubed cable I can still pull the lever with two fingers. No slipping, easy to find neutral and adjusted right no cold to hot readjustment needed.
