I just traded for a xs 650 that has the dual points setup but single coil dual wire and was not wired up i got on here and found a topic on it. and correct me if wrong but wire both points to one condensor and coil the hot wire to other side of coil? i try to start and it will start then die then slow crank also will not start without a hit or start fluid in back of carbs carbs have been completely redone by a shop but do not have any filters on yet will that cause problems where they are vaccum? thanks also when i try to use electric start it will crank great then do a slow crank try to hit then crank right
