I finally got these Emgo/commando mufflers installed. It took about an hour and a half but am happy with the fitment. I used the adapters as mentioned above. I cut the 1 piece a little long so it would feed into the muffler a little ways. The left went on no problem with a little help of a mallet and wood block. The right gave me a little trouble as the inner split sleeve kept slipping. I finally got the adapters on nice and tight though.
My first issue I ran into was the left muffler was hitting the axle. To solve this, I sourced a longer bolt in my parts stash and added a 1/2” spacer behind the mount bracket under the foot peg.
When it came to mounting the rear muffler hanger, I grabbed the stock hangers and flipped sides so the brackets angled forward. Then I replaced the puny mount bolts with some bigger bolts in the muffler channel on back. The bolts were too big to fit in the channel, so i took them to the grinder to modify from hex head to rectangular. I also had to file a small notch in the bolt shoulder so they cleared the channel. I forgot to get a pick, but will try to tomorrow. I also had to add a spacer between the muffler and bracket to fill the void of the factory offset of the hanger bracket.
Everything is nice and solid. The only thing I’m not 100% on is the passenger pegs now fold forward instead of back. I may devise a better bracket later but this will work for now. I will try to come back and edit a few more detailed pics tomorrow.
EDIT*** I forgot to add that the brake lever is really tight and if I really had to lock up the brake I fear it would make contact with the muffler. I won’t know for sure until I can road test this weekend... if it ever quits raining here.
