Srawl
Ok, I went to harbor freight and purchased the compression and leak down testers. I haven’t had a chance to do the leak down test but did a couple compression tests on each side, each with the same result. (Didn’t count kicks the first time)
These tests were done cold due to me not being able to start the bike (by either kicking or electric). The caps are in bad shape and the right side is barely sparking if at all so I ordered new caps, wires, and plugs. I also just purchased a new battery and charged and installed that.
I’m still debating what to do about coils. I haven’t looked too much into it but my thoughts on options as of now are NGK splicers, new coils, or just go with the pamco and dual tower... feel free to drop your opinion in.
Compression test was done only kicking.
Compression results were as follows,
Right side:
10 kicks- 90psi
20-110
30-115
40-115
Left side:
10- 60
20- 90
30- 110
40- 112
50- 115
60- 115
In all honesty between my lack of expertise kick starting (sure learning quick) and my tired leg, I may be the reason it took longer to stop building pressure on the left side.
I also kept track of kicks because I’ve read anything from “a few” to “a dozen” to “until it stops building pressure.” I did the last one... I don’t know if the number of kicks matters but the end result was the same both cylinders stopped at 115.
What does this tell you about the engine?
Thanks
Right side:
10 kicks- 90psi
20-110
30-115
40-115
Left side:
10- 60
20- 90
30- 110
40- 112
50- 115
60- 115
Thanks
