Converting to LED Turn Signals
zurek4
mansfield
I currently converted to LED turn signals, I have the LED Electronic Flasher relay i got from NAPA. I installed it and it works, but the problem is that "ALL 4 turn signals flash at the same time". i did some research and people said something about the single indicator light on the dash and that i need to require diodes. MY question is where do i purchase the diodes and how do i install them? help me. thanks
Buy yourself 2 diodes
Disconnect the indicator signal bulb in your dashboard
Connect one of the wires to ground
Than connect the anode from each diode to the dark green and the dark brown wire from the indicators
Twist or solder the 2 cathode to the other wire of the signal bulb in your dashboard
For diode you can buy 1N4007 (costs only a few cents, so really cheap)
On the net you can find out what side is cathode or anode
From the Super Bright LEDs link that I provided.
