Hey Peanut,
Thanks for the breakdown, sorry for the mix up but yes if I push the bike in first with the clutch pulled in then the engine still turns over. When I start the engine, I can pull the clutch in and use it as normal, however its clunks while taking off in first.
1. 1978, import from Japan with one front caliper (which I believe is what was sent to the US) The vin number is 447901xxx
2. 7 Friction and 6 steel plates
3. I have a single long push rod,
4. the bearings are on both side. (one on worm gear, other clutch basket push thing)
5 . Bearing check
6. ill get a picture of the worm gear tomorrow.
Does this give you something to work with?
5 . Bearing check
