I bought this non-runner in '14, it had started to be changed to a tracker with the rear hoop cut off and a fiberglass seat installed. Was missing the exhaust and front fender. I had it fired briefly last summer on the bench. I had the hoop welded back on as it came with the bike and I had a nice new clip on seat for it and a bunch of other stock parts. Has mag wheels with a drum rear brake. Seller found it in a property he bought, so no back story. I got a fresh title for it by affidavit.
I am partially dismantling it to clean and so on, pulled off the left cover and see that the stator looks like a time capsule. Some beige paint covers the screw at 5 o'clock. Does anyone know if it came from the factory like that or is it typical of after market. The empty points cover looks like it never had a screw driver on it so I am guessing this has never been apart. Compression dry ish with carbs on and blocked open is about 130 and 119. Someone coated the head and barrels with black wrinkle paint. I have the black carbs that came with it to clean and install.
The other question I have is about the swing arm bolt. The small nut end has gotten blued and you can see that the sleeve has wear points and a line of blue colour just inboard of the bushings. Is the latter a manufacturing result; I cannot imagine how a swing arm interior would get blued from heat.
If any of you want to comment on the rotor and the bluing on the swing arm bits, I am all ears.
