I had a headphone and one side quit working. That side measured open at the plug. Knew the problem was either at the plug or at the other end of the cable, but which? How to avoid hacking the plug unnecessarily or taking the headphone apart at the other end necessarily? How to tell which end had the problem?
Ha. My little portable meter has a feature where if you hold it near an AC circuit it beeps if the circuit is live. I connected a clip to the lot leg of a 110V plug and plugged it back in the socket. Held the meter close to the wire...beep...it's gonna work. Connected the other end of the clip to ground on the headphone plug and put the meter at the other end of the headphone lead. Beep...expected. Connected the clip to the tip on the headphone plug...beep...expected. Connected the clip to the ring on the plug. No beep, which told me the problem was at the plug... You don't have to worry about the 110V frying the headphone because there's no actual circuit being made.
