I need help having a brass bushing made for my carb. Looking for someone with a small lathe that might be able to turn this piece for me. I’d gladly pay for time, material and shipping. I can provide a drawing but basically it’s a stepped washer. I can provide specific dimensions, but off the top of my head it would be about 10mm OD, with a step down to about 6mm and a 3mm hole. Thickness would be about 3mm including the 2mm step - I need two pieces. The bushing will be used to install a heim joint on the carb of my water Buffalo, to actuate the oil pump rod. I’ll also need two 6mm OD washers with a 3mm hole X 1.5mm thick. Please message me if you can help me with this. Thanks. Vic
