Took forever to figure the dimensions for this.
Made the little vertical mount for the toggle switch.
Yesterday was definitely a BAD day for welding.
Just call me "Mud dauber".
Everything went wrong. Had trouble getting a good arc. I forgot to clamp ground. Left the clamp resting on the metal table, and the ground current somehow found its way across the table. Then the gun stopped feeding. Ohno, birdsnesting? Pulled on the wire, it easily pulled out of the gun. Now what? Oops, simply ran out of wire. Fumbled about reloading it, dropped the 2 lb spool on things that don't like excitement. Finally reloaded, back at it. *Flash* *Splatter*. Forgot to lower the welding lens, forgot to reset heat and feed. Try again (after the white spots disappear). Now I've got a good arc, but, what's it doing over there? I was a half inch off, and dobbing in the wrong place. Now the auto-dark lens decides to darken just before pulling the trigger, like it has ESP? It's falsing on the reflected lighting from the table. Ok, remove the table and move everything to the floor. Scrunched down, can't hold steady. Well, just glob it in anyway, nobody will see it. *Gads* I'm way out of practice.
Had to use the standard exchange rate of 1 hour's grinding for each 5 seconds welding. Finally got it cleaned up, and did a mock fit of the switch.
At least it's coming together...
