*Whew*, Hot day today, about 101°F. I think it hit 103-104°F out in Austin.
Inspection crew said they had to examine my work before allowing this "Hot Summertime" run.
Did some riding around home base to get the oil temp up to 200°F, then headed out to the highway for about 30 minutes at 70 mph. The oil temperature got up to 230°F, and pretty much stayed there. Stopped at Porky's hamburger shack for lunch and to get a video of the display.
Here's the display right after stopping:
After lunch, went to the carwash. I wanted to thoroughly wash the engine, to see if it made any difference.
Now, on these early engines, you can shove the carwash sprayer between the cylinders, alongside the vertical oil pipe, and it'll spray thru the cylinders, exiting to the rear, alongside the camchain tensioner. You can also spray into the crevices just behind the spark plugs, and the spray will pass thru, exiting front and rear of the head. Getting dirt/crud/spiderwebs out of these areas will help with engine cooling.
I'm pretty sure that the aftermarket "Big Fin" cylinders don't have airflow through/between the cylinders. But, I don't know anything about the '447' and '533' cooling arrangements. Do the later cylinders and heads allow airflow through/between cylinders and heads?
After the carwash ordeal, rode around town to dry it off, warm it up, and evaluate the other 'mod' (another different clutch pushrod). Then did the same return trip in this heat.
This time, the oil temperature never got above 225°F...
