A couple years ago or so I thoroughly rebuilt/restored three sets of BS34 carb sets for use in future projects. I used brand-new genuine Mikuni throttle shaft seals which I lubed inside and out with Sil-Glyde before installing.
I recently put one of the carb sets into service and discovered intake leaks at the throttle shafts. Disassembled the carb set. The throttle shaft seals had visibly swollen. A brand-new seal should be a perfect fit on the shaft with just a little drag. When removed and inspected the Sil-Glyded seals were visibly loose on a test shaft. I could actually see an air gap where the seal met the shaft. I would guess that the interior diameter of the Sil-Glyded seals was 0.25 to 0.50 mm oversize.
This is making me re-think the use of Sil-Glyde. I always thought that Sil-Glyde was 100% safe and inert on rubber. The tube says: "Ease rebuilding of rubber parts: o-rings, grommets, boots."
I love Sil-Glyde, but obviously I will never put it on a throttle shaft seal again, nor on other tiny or thin critical parts such as carb o-rings.
I have been putting it on throttle shaft seals for years, but on carbs that went into immediate use, where I'm guessing that heat, air flow, and gas vapors dissipated the Sil-Glyde.
As I recall, I got the idea to Sil-Glyde throttle shaft seals from a post made many years ago by a highly respected member of this forum. I have gotten scores of excellent tips, answers and insight from this member which I am extremely grateful for, but this was a bad one. But again, who knew that Sil-Glyde swells rubber?
This same member advocates putting a thin coating of Sil-Glyde on carb diaphragm rubbers. Something to re-think about. Might be very beneficial if it swells and softens an old, slightly stiff, slightly shrunken diaphragm rubber, but I don't think I'd put it on a nice, supple diaphragm rubber.
