Gordon in nc
XS650 Junkie
I know some of you are going to roll your eyes when you read this.....I understand completely.
I need to replace the drive chain on my 650B. I've put thousands of miles on motorcycles and ALL of them were/are chain drive so this isn't something new to me. But with the XS Im still at the lower end of the learning curve.
Here's my question. The manual makes the statement concerning drive chain adjustment that both wheels need to be on the ground and the rider in the seated position. Then you adjust to 3/4" slack. This is not an uncommon description for that task for other brands.
Did the XS's tool kit (and others) come with a tiny person that could measure the chain slack while you were seated on the bike? Just wondering.
In the real world........what do you do if you don't have any help?
On some of my other bikes.....I remove the rear shocks and pull the swing arm up so there's a straight line between it and the swing arm pivot.....parallel with the ground. Set the adjustment then hook the shocks back up and measure it again....and use that measurment from now on. On my B model XS I'd probably have to remove the mufflers/pipes to do it that way...plus I have a luggage rack and hard bags attached to the top of the shocks. I can remove all that stuff.....but would rather find an easier way if it's out there.
Again......I'd like to hear what some of you do to complete this task. There HAS to be somebody else out there that doesn't have help in the shop. The only help I have is this keyboard.....and as you've learned by now, I'm not afraid to use it.
Thanks in advance.......Gordon in NC
