I found this EFI kit:
400cc to 800cc Small Engine EFI Kits
www.ecotrons.com/400cc_to_800cc_Engine_EFI_kit.html
That's a parrallel twin. We don't have a Twin TB for it.
You need to find the TB first. We can provide the rest of the EFI kit. one example is to buy a used one, like 46 BMW F 800 TB.
I have a customer converting Yamaha XLZ 750 now.
It is going to be a customer project. You do your tuning.
thx, Matt
2 same throttle bodies linked together.
yes. You make sure the installations. We provide the rest of the efi kit.
It is a customer project then.
I will support you through the process.
$699 total price.
Thanks.
Matt
Matt Advised that I would still need to purchase a BMW F 800 Throttle Body for the conversion:
indostiker.com/2011/12/injection-kit-for-small-engines-from-ecotrons.html/
Hello all ,Injection kit for small engines from Ecotrons is useful For those of you who like to modify the engine. This time there is an alternative kit to change the carburetion system from carburetor to fuel injection. This product is named Ecotrons from America. Ease kits are provided complete and only Plug N Play. Its already closed loop injection means that there is a O2 sensor in the exhaust that could correct the result the exhaust gas by the ECU.
Not only that, also provided the software for tunning ECU. ECU can control ignition or ignition system is controlled directly by the CDI apart from ECU, so the CDI could use anything such as already programmable so that the results are getting the maximum
This EFI kit has below features:
Electronic fuel injection (EFI)
ECU controlled ignition system (CDI or inductive coil)
Plug-aNd-Play (PNP) with an O2 sensor
Dual fuel maps selectable by a manual switch (Performance Switch: ECO vs. RICH Mode)
High fuel efficiency and low carbon emissions
Decel-fuel-cut-off
On board self-diagnosis with a MIL lamp
Performance tuning for advanced users
On-the-fly calibration
www.ecotrons.com/faqs.html
Frequently Asked Questions
How easy is the EFI conversion?
The conversion is fairly easy, if you don't mind some hands-on work.
Often our customers take this as fun to convert a carburetor engine to an EFI engine.
The success of the conversion itself and the achievement of better performance, or fuel economy, or the help to the enviroment, depending on your choice of tuning, are often satisfying to justify the efforts.
