1. Dismiss Notice
    Dismiss Notice
Electrical / Timing issue? Trying to ride to BF10
Discussion in 'The Garage' started by Surfrat28, Jun 22, 2018.
  1. Surfrat28
    Surfrat28 XS650 Enthusiast
    Hey everyone!
    Bike: 1979 Yamaha xs650SG bored out to 707
    Ignition system: Boyer ignition
    I just got a new battery and it was running the other day but by the end of the day it would not turn over. The lights don't look dim but I know that its not getting enough power to get it started. I have attached the wire diagram that I had gotten help with from the forum. Could it not be charging when it is running and just drains my batter? I have even charged the battery and now it will not go. Any thoughts?? Please ignore the kick start only it is only.
  2. gggGary
    what does a volt meter says about battery condition, what battery you got? Sounds like it wasn't charging.
    "ignore the kick start only it is only. "????? I'm not fluent in gibberish. (wife would differ)
  3. Surfrat28
    The battery is at 12.35 then once I press the button for 2 seconds it goes down to 11.45. This is a brand new battery and I had road on it for about 10 miles and then when I got back home I tried to go out again and it would turn over. The main wire to the positive battery seemed to be getting pretty hot. and now the solenoid does a click every time a push the button now.
  4. 5twins
    19,390
    10,708
    813
    You need to perform the simple charging test. Pretty much all of these should have this test done when you get one then periodically afterwards. Hook a voltmeter to the battery and rev the bike up. At idle you should be seeing around 12 volts, revved a bit over 14. If you get no increase in voltage when you rev it, you're not charging.
  5. gggGary
    brand new junk batteries happen, not say'n that's it, but don't rule it out. Leave key off short solenoid terminals with big screwdriver what happens?
  6. Surfrat28
    and it is a stock battery Yusas.
  7. Surfrat28
    Sparks but doesn't want it to turn over. You can hear the compression when it tries to turn over (if that makes sense)
  8. Surfrat28
    need to get the bike started first, but will try when I get another batter sometime today and hopefully that will work
  9. Surfrat28
    With the wire diagram attached at the top should it have trouble charging when on?
  10. gggGary
    The diagram looks fine.
  11. 5twins
    19,390
    10,708
    813
    These are usually easier to kick start than electric start if the battery is low.
    As far as that diagram goes, I don't see a regulator pictured anywhere, just a rectifier. Without that, I don't think it will charge. The regulator feeds regulated power to one of the brushes (outer one), that energizes the rotor, and that makes the alternator produce an output. That output is AC but it gets fed through the rectifier and that turns it into DC that the bike can use.
    TwoManyXS1Bs, Superjet and gggGary like this.
  12. gggGary
    was guessing it's really a PMA alternator?
  13. Surfrat28
    Thank you for the help! I really tried to push it to get to that show on this build.
    Stock set up on everything except the Boyer system. Didn't make it to BF10 on that bike couldn't even get to turn over. I am guessing its either a timing issue or not getting gas somehow. It just wont turn over, I have spark, I have gas in it.
    gggGary likes this.
  14. 5twins
    19,390
    10,708
    813
    Just what do you mean by "turn over"? The starter won't crank or spin the motor, or it spins but just won't start? That would be 2 different issues, maybe not even related.
  15. Surfrat28
    Wont start. Only way we got it to get even close was to bump starting it but wants to die in seconds. Im thinking it might be a fuel issue now. I have spark.
  16. gggGary
    Wasn't what I was thinking. But my mind's in the gutter.
  17. figure8
    figure8 XS650 Guru
    Correct
    TwoManyXS1Bs likes this.
Share This Page
