garylp
Does anyone have pictures of how they put the electronics in their oil tanks?
Posted via Mobile
Posted via Mobile
Love the phone charger. I've thought about the same thing before, as my Thunderbolt's battery life is atrocious. Do you have it plugged in while you ride?
blackbetty,
what size diameter steel hemispheres did you use?
thanks
Whoa had I just had a brainstorm, while reading this thread, over my morning double espresso!
I hope I can fit, and mount everything thru the 2 3/4" hole x 6" deep????
and hope I can find a battery small enough to fit behind it!
It's an 80 electrical system......any ideas???
You guys give me such good ideas!!!! Thnx
No pics, but I can describe...
With the end caps installed on the fake tank, I took my uni-bit & made like a 3/4" hole, maybe a little smaller.. 5/8"? Up to you..
I drilled so 1 edge of the hole would be on the very edge of the cap, so about 5-10% of the hole is on the CAP, but the rest of the hole is drilled into the tank.
I removed the end cap, used my grinder & cut from the end of the tank to the hole...
So, with the end cap removed, it looks like a 2" deep slot with a rounded bottom. With the end cap installed, it looks like a round hole.
I did this because I wanted to be able to remove the wires from the tank without having to cut them... I can take the end cap off & the wires will slide right out the end as a complete unit instead of fishing thru a hole..
Before I started wiring, I installed a rubber grommet on each wire. When everything is in place, I slide the grommet thru the slot into place, everything is held in place with the end cap... I have a total of 3 holes going into mine..
