pckopp
I have looked through the Tech sections and I don't see a reference to this. I have the frame stripped with only the engine left to remove. Carbs are off, top mount removed. I would like to lay it down, disconnect the mounts and then pick up the frame minus the engine.
Some questions:
1. Left or right side of the engine?
2. Which mounts can be removed beforehand? Looks like I could remove the bottom long bolt ahead of time. Loosen the others before tipping it over?
3. Anything else?
Thanks!
Some questions:
3. Anything else?
Thanks!
