alfredo
1978 xs650 Special
good to hear man! Yes, the installation is very, very simple. Just make sure you have some circlip pliers. I got a set from a local auto shop for like $8! totally worth it.
So, I've been keeping an eye on my bike in terms of vibes, speed, and RPMs and here is the verdict. With a 277 rephase, 5th overdrive, and 17-32 gearing my highest sustainable cruising speed where vibrations are minimal is about 75mph/4kRPM. I can comfortably cruise at this speed for at least an hour before my legs start cramping, but that's an unrelated problem. Going up to 80mph/4800-5000 RPM the vibes get more noticeable. I can sustain this for about 10min before vibes numb my hand. From 80-85mph/5k-5300RPM, I can resist the vibes for about 2 minutes but they're pretty intense at this point. my right (throttle hand) in particular really feels the vibes, I'm starting to wonder if a better throttle could solve this problem.
Keep in mind that my carbs are set up pretty good, but I havn't confirmed that they are perfectly in sync. Synced carbs are essential for reduced vibrations, incase you didn't know.
Hopefully this will give you an idea of changes you could make to your gearing if you would like a higher comfortable cruise than me. I went with this gearing because I still wanted to have the off-the-line acceleration for city riding. this may not be an important factor for the riding you do...
When you say circlips, are these the same as 'hog rings'? Also, go sync those carbs . . . . TODAY !!!. That will make a massive difference in vibes if they are out of sync even a little. I learned that the hard way.
Thanks for taking time out to check this. I appreciate it as it will help myself and others set some sort of baseline of what to expect and what not to.
