Yay!
I just got my camshaft in, so I'm a few steps ahead of you at this point.
Be careful with the piston rings - I tweaked one of the thin oil rings and had to order a new ring kit and lost a night.
To torque down my cylinders to get the cam chain on I just stacked some 12mm nuts as a spacer on the studs. Worked great and once I got the endless cam chain over the sprocket I got my bearings on no problem. I used the rotor to turn the crank with - all the leverage you need.
With the key on the rotor end of the crank straight down, I believe the left side is at TDC (assuming your rephase was done to the right side as most are). Installed the camshaft with the slot pointing straight up as per manuals.
Then rotated it one full rotation which is TDC compression stroke on the left side, adjusted my tappets. Then went around to the right side and set that up. So far so good - nothing banging into anything. Will put a dial into the spark plug holes to confirm TDC and degree the cam, but it looks like it's pretty good as-is.
