Tim of DO THE TON
XS650 Junkie
BTW - another little tip I just discovered.
Regarding TDC for the right cylinder. On the right side of the cam, there is a locating pin for the advance mechanism. It is oriented the same way as the notch on the sprocket carrier, i.e. in stock form, when the engine is at TDC, it points straight up. This lets you confirm the cam is oriented correctly in an engine without seeing the sprocket carrier - put the crank at TDC using the rotor marks, and if that hole is pointing straight up, the cam is installed per factory spec.
Now, given the right side is cut and rotated forward, you can't use that hole to confirm the cam is oriented with the crank when putting the crank at TDC, as the hole has been turned forward as part of the rephase. BUT, when the right side is at TDC, the hole will in fact be pointed skyward.
So, for eyeballing it, your right side is at TDC when that hole is pointed straight up.
Not an alternative to a piston-stop method of finding TDC with a degree wheel (which is what I did) but now that I have, and I've marked the rotor with the right-side TDC, I can see that little locating hole pointed straight up when right-side TDC is aligned. Just peace of mind.
