madjack56
My 1976 XS650C is running a Pamco electronic ignition and stock (re-built) carbs. It runs perfectly, but tends to resist returning to the proper idle RPM when warm. I have explored every possible cause I can think of and have come to suspect that the spark advance is hanging up. I've installed two new springs on the weights, but it still fails to slow down as it should. If I slowly let out on the clutch while holding the front brake, it will drop down to the correct idle and stay there. Anyone have any thoughts or know where I can get some heavier springs for the advance weights?
