I have just finished reinstalling the engine in my SH following a +50 rebore. After 20 miles I checked the valve stem ends and the left side valves are not rotating. This is shown by a single scuff on the stem end rather than a circular pattern.
Just how important is this valve rotation? (I do not see how rotation can be maintained with elephants feet)
Do I just wait until the stem/adjuster damage occurs again and then fit 8mm Kedo flat ball adjuster screws?
Is there something else to be checking to restore valve rotation?
I do not really want to pull the engine again but will if necessary. It will only cost me a head gasket. Time is quite plentiful for me at the moment.
Thank you for any thoughts and ideas - Much appreciated.
- The old pistons have no dents or marks from hitting the valves historically with previous owners.
- When the engine was removed both right hand valves and adjusters were in excellent condition and the stem end showed the expected circular pattern. However, both left hand valves had a linear wear mark and the adjusters had corresponding linear grooves worn into them. This all shows the valves were not rotating prior to my ownership.
- During the rebuild the stem ends were reground, one tappet replaced and the other repolished smooth.
- All 4 valves were relapped by hand and the valves moved freely in their guides. Each valve cut a pencil lead mark cleanly when rotated.
- Following the lapping both heads were filled with petrol and showed zero leakage and identical evaporation rates with time.
