Ever use this broken bolt extraction technique?
2XSive
At least one screw loose behind the handle bars
XS650.com Supporter
Michigan
Ran across this video and wondered if anyone has ever tried this technique for removing broken bolts where the bolt is broken below the surface? I see a lot of posts asking about how to remove snapped bolts, so maybe this could be a solution?
Never on a bolt below the surface but will be trying it. I like the idea of the copper tube. Thanks for posting.
A welder is my go to for rounded nuts or snapped bolts. Even if you have to cut a nut in half to weld it on to a protruding stub on a bolt it works.
I have seen on youtube Alum used for steel bolt in aluminium it takes time and a bit of warmth.
