What you guys might want to take a look at is an SR/XT/TT500 front guide and use that as a basis for a 650 one. The big problem with most of the 650 ones seems to be the rubber coming unbonded from the aluminum base. Apparently Yamaha never figured out a good enough way to bond the two materials together. The 500 guide uses a steel base and I've never heard of one falling apart like the 650 ones do.
http://www.ebay.com/itm/1977-YAMAHA...BLY-/111712047471?hash=item1a028e916f&vxp=mtr
My idea was to try and mount a 500 guide to an old 650 base. This could be the "cure" we've been seeking if a simple "home mechanic" mounting method could be devised. A big "plus" here is the cost. A new 500 guide is only about $25. The 500 uses the same cam chain as the later 447 650s so the guide is made to use with that size chain.
http://www.boats.net/parts/detail/yamaha/Y-583-12231-00-00.html
