I was wanting to replace my exhaust since its starting to rust through. Was wondering which one would flow the best as i would like to get some more power out of the bike. Plan on redoing the jets and putting som foamies on with it
Hmmmm. Even with correct jetting for the pipes, and sensible header diameter and lengths? And a muffler that actually muffles ?Without engine work, you'll do good to keep the power the stock exhaust makes with aftermarket. You might lose about 10 pounds of weight. Louder is easy.
I thought I had always read that 1.5" pipes is what the 650 liked. I did see on the MAC web site that they're making theirs 1.75" now. They didn't used to. I have older MAC headpipes and they are 1.5".
I'm not sure exactly when a TPO on the muffler end of the pipe is needed. In other words, how big the pipe needs be before a TPO is needed.
This is part of the point to the AR inserts. Besides their "anti-reversion" effect, they also reduce the pipe I.D. for the first few inches up by the head. This promotes flow out of the engine, but once down in the pipe, a slightly larger I.D. would flow better. So, with the insert, you get the best of both worlds - better flow up top out of the head, then better flow down farther through the larger I.D. rest of the pipe. I'm not sure exactly when a TPO on the muffler end of the pipe is needed. In other words, how big the pipe needs be before a TPO is needed.
I thought I had always read that 1.5" pipes is what the 650 liked. I did see on the MAC web site that they're making theirs 1.75" now. They didn't used to. I have older MAC headpipes and they are 1.5". The big issue I had with them is the sealing lip is very small and they didn't seal up well at all. The O.D. of the sealing lip was smaller than the port which allowed the pipe to slide side to side and easily come off the seal ring. I had to make inserts from the ends of old stock headpipes to get the MACs to seal up right. This worked very well and while it wasn't my intent, I may have made myself some AR inserts in the process. Here, you can see how skinny the sealing lip on the MAC pipe is .....
The inserts stick into the headpipe, holding it perfectly centered on the seal ring. Like I said, they seal up great now. The insert is stuck into my head with some Yamabond. I also added a filler ring to fill the step in the head .....
