Quinn
S-Tracker/74frame/79motor
oh I forgot to mention... I’m getting no voltage readings directly from the bolts/wires connected to the brushes when the bike is running.
oh I forgot to mention... I'm getting no voltage readings directly from the bolts/wires connected to the brushes when the bike is running.
On the 79 the reg had a ground wire. The rec had a ground wire, On the Electro sport being a combined unit they may have combined the two grounds into one. I would try it that way. If you get no charge then try running a wire.
You get a part with no instructions for using it. Another good reason not to buy an Electro Sport. There are much cheaper ways to fix the prolem you had and this site has all the know how to do it.
The rectifier can be fixed for about $7 worth of parts, a small piece of aluminum as a heat sink and a bit of soldering. A new reg for around $30, a bit of soldering.
Not Gary but......Gary, what would cause a Alt Rotor to just fail?
