I have a '96 FZR600R rotor and an R6 RH caliper. The rotor doesn't seem to be spaced out enough, or has too little offset. If I slip the caliper over the rotor, it fouls the spokes. It is also shy of bolting up to the bracket. If I mounted it on the bracket, it would clear the spokes but not be centered over the rotor.
I suspect the NRP kit is for a stock rotor?
Spacer between wheel and rotor.
Caliper on rotor would foul the spokes.
And leaves a gap between mounting bracket. It's like I need a thicker rotor spacer.
Yeah that kit is for the stock rotor which has more offset than the FZR rotor. I am using an FZR600 rotor as well and I believe my spacer ended up being right around 10mm thick. I can go double check though.
