1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
First time rehab of a 1976ish basket case
Discussion in 'The Garage' started by LiveSlowDieWhenever, Oct 7, 2018.
  1. LiveSlowDieWhenever
    LiveSlowDieWhenever probably broke down. Just call me greasy.
    **edit, March 2019, retitled thread to avoid all xs2 confusion, read on for explanation**
    Greetings all! I recently stumbled into a new project, a 72 xs with a menagerie of shadetree mechanic work and apparent roadside cob-jobs from the headlight to tail light. I'll be posting my progress here, as well as harassing all of the experienced owners here on the forum with any questions I can't find the answers to! Gentlemen, start your engines (if your bike turns over, that is)
  2. LiveSlowDieWhenever
    Am I doing this right? Hit the reply button to expand on a thread? Never used a forum before aside from lurking.. off to a solid start with the dumb questions! Anyway, here's where I'm at so far. Basic tear down and inspection. Wiring harness had been absolutely hacked to bits and wired together with totally sub par equipment, leading to an intermittent short somewhere that caused occasional shocks via the shifter lever (who needs coffee?) so with absolutely no electronics experience I've stripped every bit of non factory wiring off. I'll be rewiring from scratch in order to retain factory color coding, since both the mike's and the niche cycles harnesses don't use factory correct color coding
  3. LiveSlowDieWhenever
    The wiring is going to take me quite some time, as I have no experience and want to do everything by the book in order to avoid confusion down the road, but the list is long as is on any rehab project. The "drag pipes" on the bike were made with mandrel bent galvanized steel and welded with a hot glue gun hot wired onto a 220 plug, so they were pulled and replaced with a $40 set of eBay headers. Left side cover is flooded with oil from pushrod seal, and left carb dumps gas from float bowl gasket if petcocks are left on. Tons of little stuff but these are the biggins for now
  4. Jim
    Jim The thrill of victory and da agony of da feet. Top Contributor XS650.com Supporter
    Yeah, you got it right. Welcome to the forum!
    12V ain't enough for a 'feel-able shock'. I suspect that's coming from the high tension side of the coil somehow...
    The K&N style filters will fit your garbage can perfectly.... they don't play nice with the CV carbs.
    We love pics. Keep 'em coming :)
    You doing a restore, mod, or just fixing what you have?
  5. LiveSlowDieWhenever
    Hello Jim! There was an absolute rats nest where the two looms met inside the crook of the frame (directly on top of coils) so I'm not shocked.. no pun intended. Bike runs a tad rich I think (dark, damp plugs) but it's hard to say as I believe it's running almost purely off of the main jets. Things didn't get exciting until above 3000 rpms on test ride. I just plan on cleaning things up and getting it on the road!
    MaxPete, grizld1 and Jim like this.
  6. Jim
    Manuals are in the TECH section. Sounds like you need to start with this well written carb guide.
  7. Jim
    Mailman likes this.
  8. LiveSlowDieWhenever
    Thanks Jim! going to come in handy for certain! Haven't pulled carbs yet, my lizard brain can only handle one problem at a time. Once wiring is sorted they'll be next on the list. I've got a clymer, and just found and ordered a factory service manual but will certainly be ears-deep in that tech section once I figure out how to properly navigate this sight
    MaxPete and Jim like this.
  9. LiveSlowDieWhenever
    That's a great article, and if I had spent any real money on this bike it would have failed initial inspection for sure. But I restored my first bike (Honda Crf230l with very little wrong and a lazy p/o) over the summer and made a big profit on it, so I'm prepared to dump some time and cash into this bike to get it right
    Mailman, gggGary and Jim like this.
  10. LiveSlowDieWhenever
    Also a little fun backstory. When I was born in 92, my dad bought a 72 triumph and it was the first bike I ever rode on (as a passenger throughout my childhood) and I always dreamed of riding it myself, but unfortunately he fell on some hard times when I was still very young and that bike was lost and gone forever. This xs2 is going to be the bike that my romanticized childhood bonneville will live vicariously through!
  11. Mailman
    I like the 1972 connection! For sure , getting your electrical gremlins and carburetor issues settled will be your major challenges. The XS2 is an early model with some unique parts on it, which makes sourcing replacement parts a bit challenging. Some things have no modern reproduction replacements and your alternative will be to post a Part Wanted ad in our classified section or do a search on EBay.
    Beware, many parts dealers will mistakenly advertise tha a part will fit later models AND your XS2, and often that’s just not the case.
    If you have any doubts about a replacement part for your bike, post your question here. The pool of knowledge here is deep.
    Welcome and good luck with your project!
    YamadudeXS650C and Jim like this.
  12. LiveSlowDieWhenever
    Thanks mailman! I'm sure there will be plenty of trials and tribs finding parts for this bike, but between the relatively large aftermarket and massive collection of information and dedicated owners here, things are looking promising. Winter is approaching and parts are piling up! Hoping to make this thread as thorough and helpful someday as your 77 build, as if that could even be possible
    Mailman likes this.
  13. Jim
    Have you pulled the points cover yet? Curious as to whether it's got OEM points or aftermarket electronic iggy....
    LiveSlowDieWhenever likes this.
  14. Jim
    Put a short name we can call you in your signature. LiveSlowDieWhenever is way too much typing for these fumble fingers...:rolleyes:
  15. LiveSlowDieWhenever
    Haven't yet, just got her in the stable a few days ago. After dinner I'll run down and snap some pics!
    Jim likes this.
  16. LiveSlowDieWhenever
    Got it, just call me greasy!
    MaxPete, Mailman and Jim like this.
  17. Jim
    Greasy... got it...:lmao:
    MaxPete likes this.
  18. 5twins
    17,134
    6,364
    688
    You should probably do some serial number checking because all of what I'm seeing is newer than '72. The motor is newer, the carbs are newer, forks, front brake and wheels are newer. The rear brake plate is from a '77 so maybe the wheels are too. The cam chain adjuster is a type D which was used on the '76-some '79 models. The carbs are a linked set of BS38s which means they may be a '76-'77 set or a '78-'79 set. I suppose it could be a '72 frame with all that stuff swapped on.
  19. LiveSlowDieWhenever
    Oh boy, I'm not surprised. A lot of things didn't look quite right but I haven't had the time to sit down and start rooting around the web for answers. Front forks/brakes are definitely not original, in fact the left fork has mounting points for dual disc config. didn't notice the other red flags.. this is going to be a more interesting project than I thought... thanks so much for the heads up. I'm totally in over my head here with almost no mechanical knowledge and this being my first big bike project, but diving headfirst into uncertain territory is nothing new and I'm chompin at the bit to learn everything I can about this thing!
  20. 5twins
    17,134
    6,364
    688
    The extra disc mount is normal on the later forks but a '72 didn't have it. After looking at some '72 model pics, your frame appears to be a later one too. Notice how the '72 eBay headpipes lower tab doesn't come anywhere near the frame mounts you have. All of this really isn't a bad thing. Parts will be easier to come by (and cheaper) for your later model assemblies. You'll just need to positively nail down the year of some of the things like the motor and carbs.
    MaxPete, TwoManyXS1Bs and Jim like this.
Share This Page
