Call couple days ago bike has been two shops idle but will not rev. I heard you are an xs650 expert. Will you make it run? Known the guy 4 years , sure drop it off so these pics are " as it arrived"
I see the right tank emblem is missing, any chance the left one is there? Seems there is someone looking for one.
Question is do you dare do anything to remove the rust as that might be the only thing keeping the gas from dropping out the bottom.
Just might not worry too much about that tank ? Check out the petcocks and intank screen condition. "Clean" the tank ? And trust the screens ? Depends on expected results by the owner..I'll try to keep it " to made it run."
I did drag in my emblems bin a couple days ago Jim, noth'n worth fix'n on, sorry.
Check the slides. They been known to get stuck.............idle but will not rev.
The clutch cable is incorrectly routed - it should go between the two carbs not down the outside of the LH carb.
Also, the fuel tank vent in the cap looks pretty crusty - perhaps it is all baffed up too and air can’t get in as fuel flows out.
