update.
Ordered John's needles. What a helpfull man that man he is.......
A couple Q's though. That john couldnt answer, or maybe I worded wrong. Before I took them apart, I checked the diaphrams by pushing the slide up, then licking my thumb,(eww, carb cleaner!) sealed the oval inlet in the bell, and released the slide. they both fell very slowly. thats what I want, rite? In though-o-ly cleaning my carbs, had the MJ's out, the Jet needles, the needle jets, everything out, except the butterfly assembly. I cleaned it within an inch (or mm) of its life. If I sprayed into a hole, I made sure it came out some where else. I put johns needles in with the middle custom spacer, new 137.5 jets,(mikes was out of 135's) checked float levels, put in new pilot plugs, bowl gaskets, mix screws. By the way, my stock plastic spacer was indeed .132, John. You were rite. I didnt include the little bump on there. Anyways, got it all back together, then checked the slides again, same method, They fell like I didnt plug the oval hole. I took the tops off to make sure I had the 'notch' in the rite place, and I didnt twist the rubber, put it back together, and still slides fell quickly. Do you guys think that in cleaning these carbs that I had removed any biult up residue in the ridge the diaghrm lip sits in? MAybe some gunk had been help seal the rubber, and I removed it? Im not saying did the carb cleaner eat the aluminum, but, is it 'too' clean now? could I put I lite coat of grease or something in the lip to help seal it?
Ok, next thing.
I ordered new clutch plates for my 1980 clutch. When I got them, I mic'd them to compare to the old ones I had. The old ones are thicker by .04 . I measuered in three separate places, and thats the average. I mentioned this to a guy at work, and he thought maybe that the new clutch material might be of different composition that might last longer, so they put less there. I dont want to use my old clutches, because when I got the motor, one piston pin broke out of the skirt, and chewed the crap out of the rest of the piston, resulting in a sand oil mixtuer throughout the motor. prolly grit in the old clutches, that Ide rather not put back in. Whats the deal with the thinner clutches? will it be fine? I also got the upgraded clutch springs from mikes. John says start off using three old, and three new. I will.
Drive plates. My drive plates are really discolored. Im sure that they get plenty hot down there, bathing in that oil, but, 3 outta 5 is dark brown, and in some places, show purple. ARe they OK? Also, when I put them on a piece of glass, 4 of the five are flat. cant 'rock them at all, but the 5th has a very slight wiggle. what do you guys make of this?
Also, I found a good front fender. good chrome. And I got a Hi-perf ciol(not the green one, the one that kinda looks stock). I was unsure about the what caps to get , so I went with the 5k resistor, and the black silycone wires. ARe these the rite caps? Do I just screw the wires onto the threaded posts(kinda look like the pionted end of a wood screw), while trying to keep contact with the actual wire in the wire with the coil contacts?
