Found in barn, XS650E
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
Actually, it was more of a damp Appalachian garage. A former in-law abandoned it in my brother in-law’s garage. He wanted it gone, so my father-in-law trucked it down to Georgia for me. I don’t remember how long I had it in the basement, but I brought it with me to Mississippi.
I haven’t decided what to do with it. I’ve considered fixing it and riding it ugly for a bit. The odo shows about 27,000 miles. It’s nasty with corrosion, in spite of being stored indoors.
So far:
The fork stop tab is bent/broken.
Charging rotor shorted.
Strainer full of metal. I guess the oil pump is toast.
A little of this, a little of that, a couple cans of rattle...
I'm sure if you look in the marketplace, you'll find everything you'll need (for cheap! :wink2: ) to turn it into a respectable rider. Maybe a daily rider! Good luck, and keep us posted (we're nosy!).
Yes, I got the front fender at Barber for $5, the side covers at another swap meet for $5. The tank is 74/75, I think from eBay. The movers put a serious big dent in it.
Got a welder? I can send you the piece I cut off the speed twin wannabe.
Get it flat again. Grinding or filing. 2 fender washers on each side and a long 6mm stud with a nut above and below to sandwich it all together. May a long bolt if one could be found could be used instead of a stud.
1+ on the #3 phillips. I use a #3 bit in a bit holder and 1/4" breaker bar. Give you lots of torque and makes it easy to rock it back and forth (tighten/ loosen) 'till it finally breaks free.
Hey that 1/4" handle is Dented!
I will always loosen/tighten starting with a hand impact...
For the tougher bolts, I have found that bringing a bit more metal and muscle to the job does the trick.
With a larger wrench, you can put more weight behind the operation.
I use a 1/2" drive.
...and for the really seized items, such as the phillips engine side case bolts on the RD350 I restored last winter (replaced all of them with SS allen heads) , I use a 1/2" air wrench. My Chicago Pneumatic has a continuously variable notchless air adjustment allowing for setting the torque zackly where you want it. This has never failed for me.
Before reaching for the hand impact, my trick, for stubborn hardware, whether using a wrench or socket, is to load some tension on the wrench, and "bonk" it with a rubber mallet. You get the momentary "spike" in torque, but it's less sharp than a metal hammer, so less likelihood of snapping the fastener. That first, then the impact. If that doesn't work, it's time for the "hot wrench"!
But it (almost) never comes to that! :doh:
