1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Found in barn, XS650E
Discussion in 'The Garage' started by jetmechmarty, Nov 7, 2019.
  1. jetmechmarty
    jetmechmarty XS650 Guru Top Contributor
    Perhaps I'll do that. It's not like it's a Brough Superior. I have another engine, though it's an '81.
    I thought the shorted rotor would be reason enough to park it. It wasn't going far that way.
    gggGary and Jim like this.
  2. mrtwowheel
    mrtwowheel Honda Etched On Brain Top Contributor
    What Jim said about not cleaning the side filter makes sense. Any place to place an abundance of extra magnets to grab on to things that might still get through the filters?
    Jim likes this.
  3. jetmechmarty
    The gaskets I removed appear to be OEM. I can't be positive, but they look it. The bolts I removed have perfectly clean threads, especially the six sump bolts. I would expect those to be dirty. Also, all seemed to have equal torque on them. The PO was a cop, not a mechanic. (Not that there's anything wrong with that.)
    lakeview, Jim, thuban and 1 other person like this.
  4. JAX71224
    JAX71224 jax71224
    I bought one but yet to use it.........
    Jim and jetmechmarty like this.
  5. Raymondo
    Raymondo XS650 owner, fettler, setting out on a journey Top Contributor
    It's a good hypothesis. Could be the person who repaired the damage which led to all those metal pieces wasn't aware of the side filter?
    Jim and gggGary like this.
  6. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    One of my favorite games XSeology, Sifting through the debris, creating a theory about what the PO did (didn't do) to create such a fine mess. It can be a useful alert to other issues that may need looking into.
    In this case removing the oil feed pipe at the cylinder base or at lease cracking a banjo loose from the head to check for oil flow may be wise. Peeking in valve cover at a cam lobes can provide clues as to engine health, history of oil changes. Seems like you can get a glimpse of the RH crank ball bearing race with the clutch cover off?
    Mailman, TwoManyXS1Bs, thuban and 3 others like this.
  7. jetmechmarty
    Does it have schwarf collecting magnets on it?
    Jim likes this.
  8. Ozboy
    Ozboy XS650 Addict
    I have the Heiden filter but yet to do an oil change. Soon tho. No magnets but both sump bolts do have magnets and large ones too. I will post when I do finally do an oil change and filter clean.
    Jim, 59Tebo, gggGary and 1 other person like this.
  9. jetmechmarty
    I adjusted the cam chain, or at least, I intended to. The pin is flush. It does not move in and out as I rotate the engine. So, does that mean the chain is new, or the adjuster is frozen?
    I adjusted the valves. Only a very small adjustment on the left side. The right side was on spec. .004 inlet and .006 outlet.
    This is not what I expected.
    Jim, gggGary and Mailman like this.
  10. jetmechmarty
    I know some of you were just talking about this someplace, but I didn’t read it. Too much wear?
    Jim likes this.
  11. TwoManyXS1Bs
    grizld1, Jim, thuban and 2 others like this.
  12. gggGary
    :agree:
    Back off the cam chain adjuster, does the pin wiggle now? A slight wiggle is more important than the exact location vs. flush. It will be fine if a bit proud and flush when it moves in.
    Good on the valves, wise to recheck after a few hundred miles of running.
  13. grizld1
    grizld1 Grumpy old man Top Contributor
    Yep, bobweights look better than most, but let your continuity tester tell you if the advance interval is good.
    TwoManyXS1Bs and jetmechmarty like this.
  14. jetmechmarty
    Yes, this is all new XS650 territory for me. All of my previous experience is on the electronic ignition models. I'm going to have to take the advance apart and lube it. I reckon I'll figure it out.
    Mailman, madmax-im and Machine like this.
  15. 5twins
    18,328
    8,559
    688
    Don't forget to lube up the advance rod too, that's very important. Your advance doesn't look bad or worn much. To judge wear, you can observe how the slash marks on the little disc and backing plate align. The better they do, the less wear you have.
  16. jetmechmarty
    I found everything anyone should need to know, here:
    http://www.xs650.com/threads/advance-rod-cleaning-73-tx650.50081/
    gggGary, Mailman and TwoManyXS1Bs like this.
  17. RadMax
    RadMax XS650 Enthusiast
    Barn Finds REPRESENT!!!!!
  18. JAX71224
    JAX71224 jax71224
    No magnet in Heiden sump screen , just in drain plugs...........
  19. 59Tebo
    59Tebo 59Tebo Top Contributor
    "....That'll do , donkey, that'll do..."
    TwoManyXS1Bs, gggGary and Mailman like this.
  20. Mailman
    TwoManyXS1Bs, 59Tebo and gggGary like this.
Share This Page
