Please add/edit/critique my thought process on tear down/inspection:
Obviously the motor will be out, and all the ancillary bits that need to be removed to open the top end will be off (pamco/advance mech/etc). So upon removing the head cover:
#1 Remove cam/bearings, inspect cam seals, clean/inspect all mating and sealing surfaces
#2 Remove head, remove valves, inspect valve seals, guides, and guide rings, replace as needed, lap valves as needed, clean/inspect all mating/sealing surfaces, check, err...flatness? of head to cylinder mating surface
#3 Remove cylinder, inspect cylinder bore, hone as needed, clean/inspect cylinder to case mating surface
#4 Remove piston rings, inspect for proper tolerances, gap, replace as needed
So cover the cleaning and inspection part of it, i think. Any input on any of that? Like, how and what exactly I should be checking.
I again want to thank everyone that has been commenting here, it's been very helpful so far. I know a lot of these answers may already exist somewhere on the board, and I'm sure I've read most of them, there is just so much to go through these days.
