1. Dismiss Notice
    Dismiss Notice
Front disk caliper in rear?
Discussion in 'The Garage' started by stanleyipkis, Jan 12, 2021.
  1. stanleyipkis
    stanleyipkis XS650 Enthusiast XS650.com Supporter
    59
    67
    18
    so cal
    If I were to run a front caliper in the rear can I expect better rear braking results than stock?
    edit: I made a mistake earlier. I was staring at a clean piston and a dirty piston and thought they were diff sizes but front and rear are the same.
  2. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    I thought they were both the same. The front calliper can b mounted to the rear bracket but the bleeding nipple is facing down instead of up........Pistons are the same AFAIK
    Team Junk and gggGary like this.
  3. Jim
    That's my recollection too. Rt front and rear look identical. Iirc, ordered the same piston for both.
    Team Junk, gggGary and stanleyipkis like this.
  4. stanleyipkis
    59
    67
    18
    so cal
    Hmm you know what I made that post before actually measuring. I need to have my eyes checked. Sorry fellas.
    gggGary, 650Skull and Jim like this.
  5. stanleyipkis
    59
    67
    18
    so cal
    Here’s the 80. She’s missing rear sets and rear caliper.
    gggGary likes this.
  6. 650Skull
    Put glasses on when measuring.......:laugh:
  7. gggGary
    gggGary When a whole one is just too much. XS650.com Supporter Top Contributor
    Yes bleed and hose connection locations only difference between all three calipers, front L, R, and rear. I always suggest bleeding rear before you install so the bleeder location not a huge problem.
    stanleyipkis and lakeview like this.
  8. fredintoon
    Hi stan.
    removing the front fender also removes it's fork bracing function.
    Pot it back or install a fork brace or the forks will be even more wobbly than normal..
    stanleyipkis likes this.
  9. stanleyipkis
    59
    67
    18
    so cal
    Thanks Fred. That is on the list of things to purchase.
    gggGary likes this.
Share This Page
