It depends on the bore size. If it has a 14 mm bore then it will work just about the same as the stock M/C. If larger, as in 16mm or bigger, it will be harder to pull the lever and the brake won't be as effective. It may even at as an on/off switch. You pull the lever and nothing seems to happen, you keep pulling and suddenly the wheel locks up. Not fun.
A smaller, like 12 or 11 mm, the lever will pull a bit easier but you will feel what the brake is doing better and the grake will be morer effective.
Usually the bore size is marked on the M/C somewhere. The stock ones, on the M/C next to the bars. Others I have seen, on the bottom. They are marked in both inch sizes as well as metric. The stock ones I have are marked 5/8 which is 16 mm, off my 75. the later 14 mm are marked 14. Some of the cheap after market ones are not even marked.
