Old thread....
While working on the 87 Radian (Yamaha, still using the same crappy fuse block) naturally several of the holder clips busted off soon as I touched them. So wandered out to the electrical parts bin and found one like this.
https://www.ebay.com/itm/Glass-FUSE...608759?hash=item41c1f00c77:g:bbUAAOSwMvBc42X6
So I got to work
View attachment 145327View attachment 145322 View attachment 145324 View attachment 145326View attachment 145325 View attachment 145328
Zim zam back in action! no wire cutting, stripping, or soldering needed!!!
Cutting the slots with the dremel took about 10 minutes total for all 8 slots, didn't even break an abrasive wheel.
Used a shrink wrap heat gun to fold the tabs on the cover in.
That fuse box is a bit pricey but but since it was in MY parts bin, I
must have found it cheaper somewhere.
May use some of that brush on electrical tape on the terminals but not too worried I drilled the plastic under the block (on the Radian) and ran in a sheet metal screw so it doesn't flop around, you can see the screw head in pic 5
