For Sale - Garage cleaning - miscellaneous, cheap
kawabunga
St. Paul, MN
Doing some garage cleaning. Would like to move this stuff. Not looking to get rich, and unless a price is stated, I'm open to just about any reasonable offer to get this stuff to a new home rather than the bin.
Mostly XS take off parts from probably a '75 or '79 (not 100% positive but that's likely the case) and there's a few random items in there.
I have some things posted locally and on other sites, I'll do my best to update availability.
2005 GSXR 600 front wheel in good shape, some chips in the paint. Tire is a Michelin Commander 2, 120/90-17 with about 50 miles on it. It's an oddball tire for the wheel, I was going to use it for a build that didn't end up using it. $200 shipped.
The spokes are in usable condition. I was able to undo them without much hassle.
No idea what these carbs came off of. They're in rough shape and missing some screws.
Fuel tank off a '79. Paint has been stripped, just has some light surface rust from sitting. A couple small dents but nothing major. Threads for badges are still there. It was repaired at one point and will need to be repaired again. It's leaking from the spot with the weld on top of the weld.
Everything in this photo I know for sure came off a '79.
HD footpeg
HD passenger backrest off a late '80's sportster
Brand new, in the package from MikesXS. Bottom end copper washer kit.
More pics available upon request. Parts are located in Maplewood, MN (near St. Paul).
Would love to make package deals!!
I hate doing the back and forth b.s. about shipping prices so please make your offer with shipping considered. Things like the wheels and forks we might have to get quoted, though.
Let's find these parts new homes!
Might be interested in cam end covers and points plate and the chrome outer round covers and screws as pictured. ZIP 42366. Not in a hurry but spare stuff has it's appeal if not too pricey...................
Is it possible to get the triple tree and risers ? I could use a carb diaphragm without holes as well.
Did I see a speedometer drive in one of those? I need one for my '78. I think all specials use the same......So how much shipped to Kentucky zip 42366?
I could separate a set of forks. What fork diameter are you looking for?
Which diaphragm are you talking about?
I'm pretty sure I have a speedo drive left. Will double check when I get back.
I need the slide diaphragm. In the top part of the carb
Oh, and the fork diameter will be for my 78. So the larger diameter
I'm interested in the grab bar and the rear special fender (with the square light). What would you do for them shipped to 91306?
Original post has been updated to reflect remaining items. I do apologize that some parts have sold since the last update. I was out of town for a week on a work trip. But, I'm back so I can sling more parts!
As for some of the questions.
@Prisondawg, @tk91j, @RC4MAN and @wannabridin, you all requested front end items. I have measured them all, I have 3 fork sizes. They're in varying amounts of completeness.
If you all happen to need items of Set #1, the 35mm tubes, I would be willing to separate those items rather than selling the whole shebang as a set.
@Prisondawg, are these the triples you want?
@RC4MAN, you inquired about the brakes so I'm including you here.
@wannabridin, are these the fork legs you want? (more photos of stanchions below). If so, do you need the fork caps? @tk91j is looking for a set and I believe these are what he's looking for.
Set #1, 35mm tubes, the most complete, adjustable fork cap. Brake caliper, master cylinder, line and junction, triple w/ tapered bearing, headlight tabs, mirrors, axle.
Set #2, 36mm tubes, forks and triple, solid fork cap.
Set #3, 34mm tubes, forks only, non adjustable cap. (That's water, not fork oil. The seals are bad though.)
@Prisondawg, the carb slides.
@JAX71224, this speedo drive work?
Other PM's have been replied to.
The set of 35mm forks have been broken down.
@Prisondawg, the triples are ready to go.
@RC4MAN, the entire brake system with tabs and hardware.
@wannabridin, the stanchions are all pulled apart.
And, @tk91j, wannab said he doesn’t need the fork caps, so they’re yours.
As for the rest, it’s still available!
I now have fork lowers in good shape, they’re yellowed but not pitted.
Stock fork springs that measure 483mm, which is oem spec.
Stock damper rods.
And headlight mounting tabs, ears, thingys with the Yamaha plate. They’re in nice shape, very light pitting on one but I think they’ll clean up great.
Okay, so not everything worked out and some items are back up for grabs.
35mm fork stanchions in great shape and 35mm adjustable preload fork caps.
Basically the only thing sold from the previous two photos at this point is the front brake system.
Happen to have a front battery tray rubber mount and the two little mounts that they hang on? Also,I have any of the tank front rubber bushings? might need those...
