plattey
Wallywheels, you are running a single vm36 then right? The slide is larger than the vm34's so that will contribute to the slide getting hung up from boost pressure. The flat slide would have a much smaller cross sectional area and may eliminate the problem. Or you can run a stiffer spring. Could you maybe order a vm34 spring and run the 34 spring inside the vm36 spring? But then spring binding will probably be an issue.......take dimensions and hit up mcmaster-carr haha!
