fullercameron
Looking to see if anyone has any good advice. I have taken these carbs off so many times now I feel like I'm ready for the friggin' pit crew.
I was having issues with plugs fouling and stumbling and eventually dying at idle. I got to the point that I figured it was the float valves in the carbs. I took the carbs apart and cleaned them and replaced the float valves and checked everything else over. The bike was running much better. No more plug problems and everything seemed in oder until I parked it the other night and when I came back it had puked about a pint of gas all over the floor.
Took everything apart and checked float height and needles again. Seemed fine so I rode it to work - gas everywhere. Took it to the shop and found that if I burned up most of the gas in the bowls by shutting off the fuel a couple of blocks before I got home, there was less of a problem. This leads me to believe that I got shitty float needles when I got the new ones - does this sound like that is the case to anyone else?
Today I took the carbs apart and checked everything again, this time I tried a bit of yellow teflon tape on the threads of the float needles because I saw it suggested somewhere on the forum, but when I open the petcock, the gas seems to be flowing out of the carburetor as though the float valve didn't even exist. Today with the air cleaner off, I can see that it is coming out of the clear tube on the inboard side of the carb as well as backing up out of the main air jet hole in the front of the carb. Is it really possible that the new float needles are this terrible?
The new parts came from a keyster carb kit from mike's. It was only 5 bucks more for the rebuild kit as opposed to just ordering float valves, so I got the lot. I'm ordering new valves tomorrow. Does anyone know where I can get real mikuni float valves? I am going to call MMM at 650 central on Monday.
I am about a week away from freaking out. Rode the bike almost 500 miles last week and I'd really like to keep going but I'd rather not be the traveling fireball.
