1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Gasket surface bump...
Discussion in 'The Garage' started by JE4570, Aug 20, 2019.
  1. JE4570
    JE4570 XS650 Addict
    104
    66
    28
    Ohio
    Hello,
    I am getting closer and closer to finishing up my rebuild. Today I was cleaning up my gasket surface on the head and noticed a bump on the gasket surface just above my exhaust valve. My head is nice and flat. (checked with a feeler guage) I must have done it while putting my valves back together. Its not huge but it is in what looks to be close to a critical spot. I plan on using the copper gasket spray.
    Is this bump life threatening?
    FB9489BD-77C2-444D-BCD8-98DA73BD7F6D.jpeg AC6D2E76-E825-4737-A4F6-23F973223C1A.jpeg
    gggGary and Jim like this.
  2. 5twins
    17,776
    7,584
    688
    The gasket doesn't reach out that far. It goes on the raised portion to the rear in your 1st pic, the part with all the little "nicks" and the groove. So, that ding won't affect sealing, it's not on the sealing or gasket area.
    grizld1, gggGary and JE4570 like this.
  3. JE4570
    JE4570 XS650 Addict
    104
    66
    28
    Ohio
    Thank you, thats a relief!
    Will using just the copper gasket spray on the gasket be all that is needed for sealing this surface? I think I read somewhere that sealer can be applied to the outside, but I didn’t see that in jims rebuild thread. Im using the vesrah kit btw.
  4. 5twins
    17,776
    7,584
    688
    Yes, the spray is all you need. Spray both sides of the gasket of course. I'd do the base gasket too.
  5. Jim
    Jim People will come Ray, people will definately come. Top Contributor XS650.com Supporter
    The copper spray is a sealer. You could add additional sealer if you wanted, but it's not necessary... the copper does fine by itself.
  6. JE4570
    JE4570 XS650 Addict
    104
    66
    28
    Ohio
    Do the base gasket with copper spray as well? Thats all I would need for that as well?
    gggGary likes this.
  7. Jim
    The spray is a gasket sealer... so yes, it would work anywhere a gasket sealer is needed. The difference with the spray is that it contains flakes of copper. This (theoretically) improves heat transfer.
  8. JE4570
    JE4570 XS650 Addict
    104
    66
    28
    Ohio
    Ohhhh ok.... that make sense I’ll give the copper spray a go for both gaskets then. Thanks for the quick replies guys. I appreciate it.
Share This Page
