1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
gear star shift adjuster, sized
Discussion in 'United Kingdom' started by Batten, Feb 12, 2018.
  1. Batten
    Batten XS650 New Member
    Looking at the shifter star it is not central to the shifter arm. Manual shows release shift arm, release lock tabs, undo lock nut, screwdriver slot till shift star is central. My adjuster is seized, any help pleeeeeese
  2. grizld1
    grizld1 Grumpy old man Top Contributor
    The adjuster is very hard to turn; that's normal, and the manuals don't see fit to mention it. As you've discovered, it won't budge with a screwdriver alone. You can use a screwdriver bit on a breaker bar or a screwdriver with a hex shank with an adjustable wrench (spanner on your side of the pond) to turn. Push down hard with one hand and turn with the other, it'll move.
    gggGary likes this.
  3. Batten
    Cheers bud. Just reluctant to try to hard and bust it. Will give that a try in the morning.
  4. Batten
    Cheers for that link. Did any of the parts make a diffrence. Pins , spring , plate.
    While i have mine apart if the pins , spring and plate make a then i will replace them.
    I have a good friend with a machine shop that should be able to make parts
    Dave
  5. Batten
    Sorted, good screwdriver and a spanner. Looked all over for one of those adjustable wrenches..
  6. TwoManyXS1Bs
    Yes, but it's a little more than that. How they interrelate, and how well they do their job makes the difference...
Share This Page
