osteoderm
out of the box
Go here for a fuse panel. http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
It's a bit cheaper. He also sells connectors. Check him out.
I'm familiar with Eastern Beaver, and looked at going that route when I first wired the bike. The Twisted Throttle Powerhub wasn't yet in production then. They are two interesting pieces to compare, and both deserve a bit more use and recognition.
The PC-8 has 8 circuits; 2 constant, 6 switched. The relay for the switched outputs is a separate unit.
The Powerhub has 6 circuits; all 6 are interchangeably constant or switched. The relay for the switched circuits is built onto the board. There are two spare fuse holders on the board.
Both use an external ATC inline fuse holder for a master. Both use ATM fuses for the branch circuits. There are advantages and disadvantages either way when it comes to keeping the switched relay on or off the board; in my own case, space constraints give the advantage to the integrated Powerhub.
The PC-8 has more circuits, but the Powerhub is more flexible re: switched/constant wiring.
The PC-8 main wiring is probably more robust/simple, with sturdy-looking lug terminals. They're otherwise both about the the same size, with basically identical construction and materials. Both are much smaller and tidier than any of the alternative encased ATC/ATO fuse blocks I've seen.
The Powerhub comes with external wiring, fuse holder, wire taps, stainless mounting hardware, mounting plate, and velcro mounts included.
The PC-8 comes with nothing, although many different levels/lengths/sizes of pre-made harness and mounting hardware are available as supplemental kits.
To where I live in RI, the Powerhub is $123.05 taxed and delivered (I paid $110.75 w/tax by showing up in person on an open house sale day).
With equivalent wiring, mounting hardware, and velcro included, The PC-8 is $119.05 delivered.
There certainly are small but justifiable reasons to choose one over the other depending on someone's particular preferences and application, but I personally can't see fit to say either is superior to the other.
