Dansweeney
Danon the mound
I bought a 1980 xs last week and the fellow I got it from had removed the ignition and has a wire that connects a red and brown wire inside the headlight. My problem now is I have fire to the points but when you hit the starter with the plugs out, it only fires 1 spark from the plugs then nothing. Sometimes it fires when you let off the starter 1 time. Could it be a grounding problems. I've tried a different coil with the same results.
