Gsxr front end question
007sparky
Liverpool
Hi peeps , just bought a gsxr750 USD pair of forks with yokes , I want to fit existing 19 mag to these forks and wondered if anybody has any experience with this swap ?
I've ordered bearings to suit mag wheels with new spindle though I'm not sure if existing discs are usuable even with spacers ?
I put GSXR forks on my XS650 using the stock mag wheel,
also twin disk/caliper. (bought extra xs650 disk on ebay)
you need to get new wheel bearings $3 each from a bearing place. 47mm OD 25mm ID
(check and make sure your axle is 25mm like mine was).
then you need to make some spacers, I used rear wheel spacers from a yamaha 250/450 mx bike (also 25mm) they just had to be filed narrower a bit.
on your triple clamps check your stem size, mine was 30 which luckily was the same as my xs650 stem so I used the bearing from that making it fit right into the frame..
