I broke the brass adjuster on the left hand VM, so had to make a new one. Instead of a hex head I knurled the head so I don't have to mess around with an 8mm spanner when adjusting. As you can see, the thread isn't much chop, the only M6 x .75 die I had was a non split die and carbon steel so the thread is a little undersize and a bit ragged. I've ordered a HSS die, so as soon as that turns up I'll make another, plus one for the right hand carb. Might make them from stainless though, stainless is bit hardier than brass. So much for the brass sleeves I made.
