79josh81
Have any of you guys wired in and used this Moto Iron universal switch on your xs650's?
http://www.tcbroschoppers.com/unive...for-7-8-bars-hi-lo-beam-turn-signal-horn.html
The reason I ask is that I would like to "unclutter" the handlebars of the larger stock switches. I was throwing around the idea of installing an after market throttle (with no switches) on the right side with a slimmed down front brake master cylinder. Then on the left side of the handlebars, I wanted to get rid of the large stock head lamp/turn signal switch and install the above switch and use the (horn) button on the switch for the bike's kill switch. Have any of you guys done this, and if not, are any of you electrically inclined enough to figure out what wires would need to go to where in order for me to be able to wire it into the 1979 xs650 stock wiring? I know some of you guys are electrical genius's with the xs650 and me...well....not so much yet.
I obviously understand that I wouldn't be able to use my electric start with this set up and I'm ok with that.
